Latest Version 1.0.4.5 Posted 7:00 pm PST 10/7/09
Keep the feedback coming. I appreciate the effort from everyone who tries this. I plan on making it as full featured as I can.
IMPORTANT: Partially tested with Vista. Please let me know if you are running Vista or Win7 and having any problems.
For bug reports, please report the bug in this thread, but send the details to my PM or email: seattle_ice@hotmail.com. I would like to keep the posts short and succinct in the thread.
After squinting at the screen and hitting enter 400 times over and over, I decided to try and automate the tasks of converting FRD and ZMA Graphs to files, and vice versa by writing a small software application similar to SPLTrace, but more automated.
I would just like to ask for a little help in testing. All feedback will be appreciated, good and bad.
For testing purposes, I have set it up as a one-click install, which means it will install from the web, but also that it will check for updates and information every time it starts. I will change that once it is finalized so it will load almost instantly.
If you need a graph to test it, you can find hundreds at Zaphs site, or many other places.
This is designed for LOGARITHMIC frequency/impedance style graphs.
This is what it looks like right now, subject to improvements and updates:
The software can be found here:
HISTORY:
Current Version 1.0.4.5
HISTORY:
- FIX: 9/28/2009 - Error when manual entry made to frequency combo box. Frequencies are now limited to existing entries.
- FIX: 9/28/2009 - Error when entering manual amplitude numbers. Manual entries are now allowed and should work fine.
- FIX: 9/28/2009 - Dialogs would get trapped behind Help form. Help form does not stay on top anymore, to view it while working you must move it to the side.
- ADDED: 9/28/2009 - Ability to handle Impedance data.
- FEATURE: 9/28/2009 - Logarithmic calculating and drawing functions have been sped up aproximately 3-400%.
- FIX: 9/28/2009 - Manual entries are allowed for Impedance values.
- FIX: 9/28/2009 - Impedance colors and text not reading right.
- FIX: 9/28/2009 - Impedance values not reading correctly.
- ADDED: 9/29/09 - Color choice for tracer.
- ADDED: 9/29/09 - Prompt for manual input via arrow keys if tracer gets stuck.
- ADDED: 9/29/09 - Whole new level of AI on the tracing functions. It now will track trends up to a depth of 10 points along your line, to help stay on the correct line when multiple lines intersect.
- ADDED: 9/30/09 - Ability to open and display *.frd and *.zma files.
- ADDED: 9/30/09 - 5 options to handle duplicate frequencies showing up to due pixel width. You can keep, remove or average forwards/backwards.
- ADDED: 9/30/09 - Trace handling for the graph line going off the edge of the graph before the user limits were hit. This would cause a fault.
- FIX: 9/30/09 - Index out of range fault when processing duplicates.
- FIX: 10/3/09 - Tracking lines were being drawn offset when graph was visible with scroll bars.
- ADDED: 10/4/09 - 3 options for different impedance scales
- FIX: 10/4/09 - Error when loading a file that contained points that resulted in duplicate pixels being drawn on the map.
- FIX: 10/4/09 - Data Point Save forms were not properly remembering the last percentage setting. Now the last choice is persisted.
- ADDED: 10/7/09 - Start the trace anywhere on the line, instead of before the selected ranges only.
