DIY Sound Absorbing Panels II
  • PMazz
    • May 2001
    • 861
    Well, a little OT, but what the hell!
    Having just moved the shop to a new building, the current level of noise from the machinery, and especially the dust collector, is just about driving us crazy.
    The dust collector is a recirculating bag type. It's about 9' long with two 8' filter bags coming out the top of 2' diameter collars which have 4' plastic bags attached at the bottom to collect the dust and chips. The motor is 7.5 HP 3Ph and it SCREAMS.
    Since it's located in the center of the shop floor near a column, my thought is to make an hanging enclosure out of semi rigid OC 703 2" thick fiberglass panels, which I found for a good price. The absorption coefficient looks like it should work well.
    So what do you guys think. I have to leave access to the bottom bags for disposal. I thought to surround the top filter bags with these panels and then fill in some of the surrounding areas with it also. I may also buy extra to make wall panel absorbers with, as needed.
    Pete
    Birth of a Media Center
    • 27461
    What shop, what building, lol?
    Lex
      Guess if possible I build wooden cage around the whole thing and cover it with multiple layers of the glass panels. Use fence like gates to access the bags....
      • PMazz
        • May 2001
        • 861
        Lex, if you feel this is inappropriate, feel free to delete. I just thoght I'd throw it out here to here some opinions.
        Tom, A full surround is probably not possible since there is a few pieces of equipment surrounding it as well. My thought was to apply some of the panels to the back of some of the stuff as could fit. I was considering doubling up the panels, but thought I'd try a single layer first.
        If I can get a decent pic of the setup I'll try tomorrow.
        Pete
        • PMazz
          • May 2001
          • 861
          Here's a couple pics of the collector.
          Pete
            • 27461
            oh no Pete it's fine, some shop!
            I just didnt' know the answer, so just had a little fun.
            Lex
