Damping for enclosure?
  • PMazz
    • May 2001
    • 861
    TW, I was wondering if you ever got around to playing with that roofing material/sand mix? I have some drivers ready to go into some enclosures and thought I might give it a whirl if you thought it was worth it.
    Pete
    Birth of a Media Center
    • 10931
    Pete
    I made one sealed M8a-MKIII box plain and one with a thick layer of the material. Doing a knuckle rap test the damped box has a more dead sound. But I can't really say that adding the material results in better performance. The performance of the two boxes sound the same. Now these designs have restricted LFE given the very small size of the box, so it will probably reqiure a sub or something similar to do a real test.
    The rubber roofing membrane is cheap ($15/gal), so is sand, you might want to experiment
    • PMazz
      • May 2001
      • 861
      What was the brand name of the roofing stuff? If I remember, it was a latex based product.
      Pete
        • 10931
        Kool Coat. I bought it a Lowe's
        Recipe is put 2 coats on of the straight stuff. Then mix up an batch containing a ton of sand. Apply as many coats as you want. Then cover with 2 additional coats of the straight stuff to seal the sand in
          • 8938
          Thomas,
          How much weight does this material add? A lot? Just curious.
          David - HTGuide flunky
          Our "Theater"
          Our DVDs on DVD Tracker
          • PMazz
            • May 2001
            • 861
            Thanks Tom!
            Pete
              • 10931
              David
              Depends on the amount of sand added to the mix/the size of the cabinet/ and the thickness of the layer used. So I can't give you a exact number. Certainly several lbs to an 'average' sized cabinet
