Speaker driver hookup wire?
  • Brandon B
    • Jun 2001
    • 2193
    Would this
    be good hookup wire for between XO and drivers? If so, what gauge(s) would be apprpiate for 100 watt tweeter/series pair of 70 watt mids in an MTM?
    Thanks.
    BB
    • 16507
    Brandon I edited your link so it was clickable. In order for URL's to work properly you need to either use the URL function above or simply add [url] and [*/url] around your quotes (minus the *)
      Yup should be fine.
      I use single run of 16 gauge MIL spec from Belden for the tweeters, then double it up for the woofer,
      • Brandon B
        • Jun 2001
        • 2193
        Thanks Andrew.
        Thanks Thomas.
        BB
