Measurement mic, software
  • Steve Goff
    • Feb 2002
    • 186
    Well, my old, old Audio Control 1/3 octave RTA has given up, just at the point I wanted to put my Rane PE-17 between my processor and my sub. So I'm looking into a measurement mic and software for my laptop (full duplex sound card), to use in equalizing my sub and for getting back into speaker design. I'm thinking about the ETF software and maybe their mic/preamp package, but would like to know about alternatives, such as the cheap Behringer mic. Any help will be most appreciated.
    Steve Goff
    Steve Goff
    Steve
    This LINK will get you started
    • Steve Goff
      • Feb 2002
      • 186
      Thanks, Thomas. Have you had a chance yet to try the Behringer ECM8000?
      Steve Goff
      Steve Goff
        Steve
        We have 3 of the ECM 8000s but haven't had the time to do a direct comparison with the B&K.
        Using the 8000 with the DSP110 plugged into a PC there is a roll-off starting around 12Khz. We aren't sure if it's the 8000 or the DSP 110 causing this (probably it's the digital processing in the DSP110). It's not really all that important for most uses because there's very little one can do to adjust frequencies that high.
