I am utilizing a pair of Zaph SR71's for two channel duty, and I would like to somehow offload the lower octave work, or protect them from needless excursion at volume. I am using an Anthem Integrated 225 for power, and because this amplifier has no means to route the LFE content to my subwoofer, I really feel as though my mains are being subjected to copious amounts of needless excursion. Would it be wise to invest in some Nerf balls to stuff the ports of the SR71's? Or is there a superior solution, perhaps electronic, that I am not aware of. (Judicious volume control aside)
Protection of small mains when run fullrange
Get an electronic crossover such as a Behringer unit. You'll need a sub amp and subwoofer for the low frequencies then.Originally posted by CataclysmI am utilizing a pair of Zaph SR71's for two channel duty, and I would like to somehow offload the lower octave work, or protect them from needless excursion at volume. I am using an Anthem Integrated 225 for power, and because this amplifier has no means to route the LFE content to my subwoofer, I really feel as though my mains are being subjected to copious amounts of needless excursion. Would it be wise to invest in some Nerf balls to stuff the ports of the SR71's? Or is there a superior solution, perhaps electronic, that I am not aware of. (Judicious volume control aside)- Bottom
HP your mains with an electronic crossover.Originally posted by CataclysmI'm running a Rythmik Audio servo sub, so I have no issues on that front.- Bottom
Having a sub doesn't matter if you don't have a way to manage bass on the main front speakers.
Most AV amps can be set to 'Small', meaning the low bass is not directed to the fronts. That will save you cone excursion on the fronts. However, your amp does not already have bass management built-in.
If you have a sub, then the best bass management, assuming you have a stereo amp, is to simply turn down the BASS control and let the Subwoofer fill in the low bass. That may not be ideal, but it is certainly the simplest.
When others suggest you add an electronic crossover, it is to separate the low bass for the subwoofer, and to direct the midbass to you main speakers.
Again, this all assumes stereo. If you had a surround sound multi-channel AV amp, then likely that amp has some bass management built into it. Correct configuration of the AV amp will give you exactly what you need.
Your options are limited without some means of filtering and separating the low bass from the midbass, and the only way to effectively do that is with a crossover.
It is possible if your sub has high level/speaker level input, then it might have speaker level outputs. If it does, the Sub filters low bass from the Subs speaker level output. Though it does this by simply putting a huge capacitor in series with the speaker level out. That works, but most thing it is very unreliable, somewhat sloppy, and not the best for fidelity. Still, it works.
So, either use those Speaker Level Outputs on the Sub, or use an electronic crossover.
Steve/bluewizard- Bottom
by DS-21I've found myself with a little time to breathe, and I'm going to upgrade my mains. The main point of this upgrade, honestly, is aesthetic, because big grey studio monitors are ugly. But since I'm going to be spending the money on new cabinetry anyway and my new-to-me receiver (Denon AVR-4306, bought...-
Channel: Mission Possible DIY
by AntonAfter alot of searching and question asking I finally picked up an all in one surge protector and mains filtering power board from Surge Shield, namely the Premium A2 (http://www.surgeshield.com.au/a2.htm) I was so impressed when I first fired up my system and had a long listening session, it opened...-
by technodanvanExcursion
Excursion refers to the movement of the speaker's diaphragm or cone. It represents the maximum distance the diaphragm can travel back and forth from its resting position when driven by an electrical signal. Excursion is typically measured in millimeters and is an important specification in loudspeaker design. It determines the maximum displacement capability of the diaphragm, which directly affects the loudspeaker's ability to reproduce low-frequency content accurately and...-
Channel: Terminology
18 July 2023, 15:29 Tuesday -
by Greybeard191I'm playing around with a Tumult 15D2 in Unibox and I've run into what seems to be a conflict.
If you build a 2 cu ft box and set input power to 1000 watts, Unibox says on the sealed box that that excursion of 33mm is exceeded at about 30 hz or slightly under (on one of the graphs). Yet...-
by A9XHi All,
I'm an experienced designer and builder of speakers and have a set of large JBL and BMS based mains* designed and will begin construction soon.
Once these are done, I'll turn my hand to a set of rears, and I need some advice to what sort of performance I should...-
- Loading...
- No more items.
