Here is where I am currently with my design and I feel fairly comfortable with the numbers. This was calculated with WinISD.
SPEC:
Dual ACI SV10s
Passive Vented Design, with front/back opposed drivers, port also on back.
Enclosure of 2.85 cubic feet.
I will likely be using polyfill to get an effective 25% size increase.
Port will be 4" Diameter at 41.5" long.
Drivers, bracing and port are roughly .45 cubic feet.
This should result in a 3.0 cubic foot enclosure tuned between 16-18Hz.
I will have two of these.
This will ultimately be EQ'd.
At MAX POWER for the drivers (500 Watts for two), I get...
SPL:
94 dB at 10 Hz
106.6 at 20 Hz
111 at 30 Hz
112.6 at 40 Hz
113 at 50 Hz (with 1 dB up from there)
GROUP DELAY:
15.2 ms at 20 Hz
9.8 ms at 30 Hz
6 ms at 40 Hz
4 ms @ 50 Hz (drop from there)
PORT AIR SPEED: (I will have large flares on the ports)
19.6 m/s at 20 Hz
9.7 m/s at 30 Hz (continues to drop)
DRIVER EXCURSION:
XMax + 10%
Any thoughts/improvements on the design are welcome, but I think this should give a great result in not much space. Hopefully when combined with room gain and the equalizer, it will give quite the quality bang for the buck.
Agree? Disagree?
Thanks!
SPEC:
Dual ACI SV10s
SPL:
94 dB at 10 Hz
106.6 at 20 Hz
111 at 30 Hz
112.6 at 40 Hz
GROUP DELAY:
15.2 ms at 20 Hz
9.8 ms at 30 Hz
6 ms at 40 Hz
19.6 m/s at 20 Hz
DRIVER EXCURSION:
XMax + 10%
Agree? Disagree?
Thanks!
