New project - "Center 180"
  • brianpowers27
    • Feb 2009
    • 221
    Here is the scoop... I built something that other people might actually be able to reproduce. I hope the tb 2" mid doesn't go out of production....
    3 way center channel.
    • 32l -
    • 2"id x 8" port--- Tuned to 32hz?
    • Wide 24
    • Tall 8
    • Deep 15
    Parts
    --Dayton nd20fb
    --rs180-4
    --Tang Band 50-1426SA 2" Textile Dome Midrange
    XO info --
    3rd order bw all the way around.
    I can't say I have ever considered using these as mains. I am sure they would be ok but I would consider rearranging the tweeter and the mid for optimal dispersion. They have gobs of bass potential. Could be used full range but will take huge power when crossed to a sub at any reasonable Frequency >60hz.
    The construction...
    --.75" mdf for the baffle
    --.5" mdf for the sides
    --one window brace from front to back, full height.
    --Lined with 1.5" rockwool 60
    --4 pair subwoofer terminal for external xo
    --External xo (one in, 3 outs.)
    --Large chamfer on front and back...(1"-1.25" cutting length)
    --Port fires out of rear, so you don't hear the port...
    It works pretty well. ..
    P.S. My measured on box FRD/ZMA and PCD files are attached to the zip...
    --My Speaker building pages http://sites.google.com/site/brianpowers27speakers/
    --Get yourself on this forum member map! This can help everyone find fellow DIYers in the area.
    --The Speaker DIY resource Database
