DIY Speakers .....?
  • Stoopalini
    • 99
    DIY Speakers .....?
    I've been contemplating building my own mains lately, and think I might just go ahead and do it.
    I have looked at the Adire kits, and the 281's will probably be my choice.
    I like the ported design best. They go lower in Hz and I prefer the towers too.
    Now I know I could just put the sealed version on some stands, but then I loose some low end there.
    Anyway, this is still way in the infancy stage and my real question is this:
    If I build two mains using the 281 ported design, I was wondering what kind of center I could use. Then I thought, what if I built one one more 281 with the sealed design and used that as a center channel?
    Would this be feasible? I have never seen/heard a center channel with dual 8" woofers.
    What are your thoughts on this?
    Any input is greatly appreciated
    Thomas.
    • 16507
    well Mike Knapp over on the Home Theater Talk site built those and a single as a centre...try Avatar kits
      • 10931
      Yes build the dual 8" sealed like Mike Knapp did. This will give the best match for the tower ported mains.
      • MikeK
        • 16
        I built the 281 sealed cabinet as my center and mounted it on a stand to make the tweeters all line up. I couldnt use it vertically with the tweeters lined up because it would be in the way of my screen. I made two of the single 8" driver Kit81's as my surrounds. I couldnt be happier with this set of speaker....proceed, and do so quickly!
        Mike
          • 10931
          Yes proceed, but don't use a green woodgrain finish
          • Stoopalini
            • 99
            alright! I guess the decision is made then. Time to order 3 of the 281 kit's and start buildin' !
            Mike,
            Great job on those 281's! they look great, even with the green (so they tell me -- I'm color blind )finish. I could only hope that mine will turn out as nice.
            As far as mounting the center, I have a 36" Wega set in a rack with adjustable shelves. (Here's an old pic of it: My Entertainment Center) so I shouldn't have a problem moving the TV up a little and making a shelf underneath it to put the center on. This way, all the tweet's will be in a plane at ear level.
            Thanks again guys,
            Thomas.
