I'm in the planning stages of the basement theater and want a very clean looking install for the speakers. I'm pretty much set on using Natalie P in-walls for the L+R and Modula in-walls for the surrounds (unless someone can convince me otherwise) but can't seem to find a center channel that will keep up with the Natalie P's. I want the ability to play loud as they will be flanked by a formidable IB subwoofer. I also like having MTM speakers due to the decreased vertical response to minimize floor and ceiling reflections. The room won't be very large, only 11w by 16d, which is out of my control. Something about my wife needing a computer/office area in the basement as well...
With that, does such a design exist and I just can't find it? Would using a horizontally mounted Natalie P be that detrimental to the off-axis, even though the room will only be 11' wide and only have a single couch in the center?
