Hi all.
A couple years ago I built a subwoofer using the Dayton 15" DVC driver and a 240 watt Dayton plate amp. I don't remember all the exact measurements now, but it's about a 225L enclosure with two 4" flared ports. I think tuning was to about 19Hz.
I've never really been entirely pleased with the performance of the sub. It just never hit the lows the way I was expecting it to - rolls off to nothing below about 30Hz. It's also got a pretty bad (like +10Hz) hump around the 50Hz point. Some of this could be due to room acoustics, which are not ideal, but testing with the SPL meter even right next to the box seems to indicate that it's really not hitting the lows like it should.
The only really unconventional thing I can think of that I did during the construction was orienting the ports to fire upwards. The box is taller than it is wide or deep. The driver is front firing, and the ports are oriented to fire up. Amp is in the back. I can post a pic if this description isn't clear enough.
It's been a couple years, but I find myself in need of a new project, so I'm thinking about starting over and building a new enclosure for the driver. Before I do that though, I want to ask if anyone has an opinion on upwards firing ports, and also if anyone has any other suggestions for my new enclosure. If I'm starting over from scratch, what would be the best port orientation? Forwards? Backwards? Down-firing? I don't want to have to build a third one. I'm hoping to get this one right, so I can start building my Natalie P's next. :P
