Need help choosing/designing speaker enclosure..
  • elves1111
    • Mar 2008
    • 3
    Have been searching online for a long time now, and can't find any solid info. I have a pair of Focal TC120tdx2 1" inverted dome tweeters and a pair of 8" Focal 8v413's(can't find the specs for anywhere!!, but i read that the 8v412's are close, but not sure). I also have two NHT 1259 12" subs that i would like to incorporate into the design, but can build into its own box later, to make this project simpler. I am after a design that can play aggressive acid jazz/techno sometimes heavier with plenty of distortion while being able to maintain sound quality and intricate detail while switching from that style to some smooth jazz or rhthym and blues. In a studio setting also. If anyone could direct me to where could start or any sort of info, please......... will be very greatful!!!!!!!!!!
    • 15290
    Read this for some ideas
    This might help with some ideas. Same configuration, one version was done with the same tweeter, one with the same woofer.
    M8 Reference paper
    Right click and download the link- it's a 48MB PDF, your browser may barf trying to load it into Adobe reader internally- mine doesn't, but for many others on the forum, it's a problem.
