We begin to get into smaller concerns where your desired woofer and your desired cabinet direction can all work together.
Center to center spacing needs some attention, relative to frequency wavelength at crossover points. You also have the woofer quite close to the floor where it'll have more floor bounce issue (but also more boundary gain) so that should be considered. Woofer to lower mid is probably just workable assuming something in the 200Hz range. Lower mid to upper mid, I'm not so sure will work, though having this (upper) be more of a "filler" driver than a full on crossover (where there is also significant overlap between the lower mid and the tweeter, and this driver is probably -3dB or -6dB from nominal) you begin to have something workable. Even something like a dome mid could do well here.
We're getting to where we need to consider what other drivers to put into this package. I think that once we consider baffle step, we'll be looking at 90-93dB (depends how floor boundary gain goes) nominal - let's take a look over our tweeter options to find something that's in that ballpark and see where that leaves us on crossover frequency options which will help with the choice of the remaining two drivers.
