Looking for something small
  • NyxOne
    • 184
    Hi everyone,
    My wife wants to have a small stereo system to replace the TV speakers. The only problem is that it must small (bose small), less then 7 liter and located close to wall (less than a foot).
    So obviously what I'm looking for is a fullrange or 2 way with a woofer ranging from 3 Inch to 4.5 inch. They don't need to go low or achieve high SPL. They will probably be crossed to a subwoofer in the 80-100hz region.
    I've searched thru HTGuide and found Lineup F4 and D4 but the enclosure looks too big (just by looking at the picture, i haven't found the volume) and the D4 tweeter is gone (RIP D26).
    I've found Zaph B3S and N3S design but i'd like to have more options! Something with a small tweeter a bit like the Amethyst Micro Monitor ?! In the full range departement and also considered : MarkAudio CHR70 & CSS FR125.
    Any suggestions or comments are welcome,
    Chuck
  • Undefinition
    • 577
    I think that "Amethyst" looks like a really solid design.
    In a similar vein, there is my "Buggles" design, which uses the HiVi B4N + Dayton ND20. The box is pretty small (4.5 Liters). (I also did a version with the M4N--which does better midrange than the B4N--but it's sealed, and thus needs to cross to a sub) I haven't gotten around to finishing the writeup for them, but I have all the cabinet drawings and XO diagrams if you're interested.
    Also, Wolf (from Parts Express board) has a similar design called the "Sophomores," which uses the HiVi M4N + TN25
    • NyxOne
      • 184
      I might be interested in the B4N version! I've read (PE forum) that you are planning on making a version with less BSC ? It would allow me put them very close to the wall (like a said, <1ft, almost wall mount)? Are still planing to do it ?
      EDIT : I've just took a look at Zaph measurement of the TN25 his level of distortion is pretty high compared to Dayton_ND20FA-6 OR Dayton_ND16FA-6 and their price is pretty much the same! Is there any reason why you choose the TN25 ?
      Thanks for the input Undefinition,
      Chuck
      • BOBinGA
        • 303
        Chuck,
        Take a look at Roman's Microbe SE:
        It's a little more expensive, but the components are top notch.
        -Bob
        -Bob
        The PEDS 2.1 mini system
        • Jed
          • 3621
          If you want to help me build the new D4 replacement let me know. Maybe you could send boxes and we could order the parts together. Then I'll measure it and send everything to you when done.
          I'd like to do a TM with W4 1337 and the Seas 22Taf-g.
          • NyxOne
            • 184
            Originally posted by BOBinGA
            Chuck,
            -Bob
            BOBinGA,
            I already know them and I'm sure they're great but like I said I'm looking for something small... really small, less then 7 liter. I pretty sure those are bigger than that and looking at the sensitivity (81db) of final system they must have at least 4 db of BSC (not good when close to a wall like I want it to).
            The price is not an object here (don't go wild with this statement). I don't mind putting a few extra buck to have good sound!
            Thanks for the input BOBinGA,
            Chuck
            • NyxOne
              • 184
              Hi Jed,
              interesting offer especially from you Jed! ;x( ;x(
              Unfortunately i must decline your offer as I'm pretty sure W4 1337 require >= 7 liter (I haven't done anything simulation and can't right now... [I'm not at home]). Like I said this project is driven by my wife, not me... so I need something small. Also I don't know if she would agree to wait any longer since it's been a while since she first asked me ... (I'm a bit on the lazy side).
              EDIT : Well now that i'm home i've done some simulation and it looks like the W4 1337 can fit well in a very small enclosure! (<5 liter) . One thing is sure, the F4 is now my list! I'll read the thread about it ASAP.
              Again, thanks for the generous offer Jed,
              Chuck
              • HareBrained
                • Jul 2008
                • 230
                Here's a speaker that I designed and got spousal acceptance:
                You could build it sealed in 5L and still integrate with a sub. The woofers are shielded and they sound really good. If you have Nik Brewer cut the baffles, it's a simple build.
                John
                • NyxOne
                  • 184
                  Hi HareBrained,
                  huummm.... this design is a bit over my maximum allowed volume (vented) but the fact that it's an MTM, cheap and can get low is very tempting!!! It's a shame that you don't have any measurement! In any case this one is on my list now!
                  EDIT : BTW, what's a "Nik Brewer" !? Any pics/url?
                  Thanks for your input HareBrained,
                  Chuck
