Hello all. Well after having listened to the big RS 3ways for some time I am still left wanting more bass, so I have decided to stop messing around and use dual 15'' bass bins to get some real kick in the chest action. I am looking at the Dayton Series II, ST385-8 with:
Power handling: 300 watts RMS/425 watts max Voice coil diameter: 2-1/2" * Le: 4.25 mH
Impedance: 8 ohms
Re: 5.8 ohms
Frequency response: 20-1,000 Hz
Magnet weight: 90 oz.
Fs: 19 Hz
SPL: 89.8 dB 1W/1m
Vas: 10.63 cu. ft. or 301L
Qms: 8.30
Qes: 0.33
Qts: 0.32
Xmax: 7.9mm
But I am open to suggestions on other drivers.
I listen to rock, techno and that kind of stuff, no jazz but maybe a little classical in the mix. I tried to model this driver in WinIsd with the parameters according to the well known tutorial...and again, it does not work at all. I will not try that program again, I have tried for 6 years to no avail. I tried Boxplot and if I did it correctly comes out to a box that can be 15'' x 15" x 21".
Could someone that knows what they are doing, unlike me, run this driver and see what box size comes up? I need it 15"x15"x? And it Must be sealed. Thank you all in advance :T
Impedance: 8 ohms
Re: 5.8 ohms
Fs: 19 Hz
SPL: 89.8 dB 1W/1m
Qms: 8.30
Qes: 0.33
Qts: 0.32
Xmax: 7.9mm
