Hi All,
I've built some tower speakers in HS as a class project years ago. Recently, my sony towers broke, and I found my old tower in the attic and decided to use them. I was very happy they still work, in fact they sound better than the Sonys. I had forgotten how they sounded. Now I'm thinking of building an entire 7.1 system and I need some advice.
My design priorities are:
1. Price
2. Performace
3. Looks
If they can look like a polk monitor 50, cost less, and perform better, I'd be really happy.
However, I can't do any thing too complicated since I've no woodworking skills. I can read a circuit diagram, plug in some equations, and soilder.
Step 1
I've picked out some speakers already in the below configuration...
L-----R------C-----LS------RS------BLS------BRS
T-----T------T-----MT-----TM------MT------TM
M-----M--W_M_W---W------W-------W-------W
W----W
W----W
They will all be ported. I tried to pick out three speakers with similar looks and ok cost wise.
Tang Band 25-1719S 1" Ceramic Dome Tweeter x 7 T = $133
Tang Band W3-315E 3" Aluminum/Magnesium Driver x 7 M = $150.99
Dayton DA175-8 7" Aluminum Cone Woofer x10 W = $245.60
Total = 529.59
Any advice on my choices?
Step 2: Cross Over design
This will be a major challenge for me. I need to know where I should start. With those speakers I'm thinking of a 3-way at 500/5k.
Step 3: Encloser design
I think I can use software to get me a basic box design. Maybe I can get a head start here with help on what type of wood working tools I would need.
Hope to hear back soon
Thank You All!
1. Price
2. Performace
3. Looks
Step 1
W----W
W----W
Total = 529.59
Thank You All!
