My wife and I put an offer on a house and we'll get the answer early this week. If we get the house, I won't be able to go with my previous plan for speakers (the full size Statement towers). Required speaker location makes sealed front speakers a must... and I really like the RS225 woofers.
So one option would be to make three large sealed Frodaddy Statement Centers and use them as horizontal LCRs (since they are not only sealed but do not have the open back mid). I would then use the Statement Monitors as surrounds. The only problem is they would need to hang from the ceiling. I'm a little worried about how that might actually work... especially since the HT will be in a loft and the speakers will be visible from the formal living room. As much as I'm really intrigued by the titanium mid and Fountek ribbon, I have my concern about the practicality of the surrounds in my particular situation.
Another option would be to do two Khanspires, one Khancenter and four In-Khan-Neatos (as built in ceiling mounted surrounds). The latter would be simpler and look better (and despite being ceiling mounted, they should sound reasonably good). I could also have three Khancenters and use them as LCRs. The thing is... I really like the RS225 woofers. Accordingly, I could go with the W-M/T-W speakers found in this thread. My understanding is the ones with the crossover done by cjd should mate with the In-Khan-Neatos reasonably well. If I went with those W-M/T-W speakers, I could make three of them and use them as LCRs. Or, could I use one and use it as a center and use the Khanspires as L and R speakers? This way all three front speakers would use the RS225 drivers (and thus all three could be crossed over to the sub at 60H), but I wouldn't give up the sensitivity and dynamics that go with vertical WMTMW towers. Do you guys think that last combo would sound coherent across the front sound stage?
Thanks in advance!
Thanks in advance!
