I was all set and ready to order the stuff to build the BAMTM when I decided to research what nominal ohm load they are because I wanted to power my first speaker build with my old pioneer 514 which is rated at 8ohm. You can see my problem now, is there a cheap stereo receiver that will power the BAMTMs ? I'm talking 100 bucks or so. my other option is to build some 8 ohm speakers like the tritrix, but as I am going to build statements for in the HT room I would like to try another designers budget design. by budget I mean under $200 for drivers and crossover components, I also want then to be "bookshelf" MTM speakers because they are probably going to be mounted from the rafters angled down in my shop that is 14x18. I got to jam out when working on my Statements.
Thanks in advance, :T
Gavin
Gavin
