I am in the process of building 7 speakers for my HT. They will all be 3 way OB/Dipole. The fronts are in a line array configuration and will be using a active crossover until I get them tweeked to my liking. Then I would like to build a crossover based on the Behringer DCX2496 settings. My question is, is there software I can simply put the active settings from the DCX2496 into the software and print out a passive wiring diagram and parts list?? Or am I dreaming??
Best crossover design software??
Many OB designs (the orions come to mind) use an active circuit that actually boosts the bass frequencies to accomplish a flat frequency response. This technique will be possible with the Behringer, but simply impossible to translate into passive components... regardless of software.
Of course there are people who use passive crossovers for their OB designs (see JonMarsh's Arvo Part thread) but if I were you I would do it exactly the opposite way you described. I would use a modeling software (I use soundeasy, but lots of guys around here use LspCAD) to design a passive crossover then either program the Behringer to emulate the passive crossover or use the emulator built into the modeling software to evaluate the design through your soundcard (I know soundeasy offers this, but I think LspCAD does as well).
Passive crossovers for OB are pretty hard to design from the sounds of it... heck they are hard enough to design for a standard monopole 2-way!
Best wishes on your project,
-Chad- Bottom
For an OB design, have you looked at Jon K. ABC Dipole?
You'll still need Soundeasy, Speaker workshop, or PCD, but that ABC Dipole will probably help significantly.- Bottom
Originally posted by ch83575but simply impossible to translate into passive components... regardless of software.
The OP must have a very large room to accommodate the placement of 7 channels of dipole loudspeakers.
Thanks for all the info. I looked at Speakeasy and abc dipole, I think I will get them both, The Speakeasy is very expensive!
I am really not stuck on any one thing, I just want a set up that sounds good and am going to adjust based on all the comments. I will run the mains Dipole with the active crossover and box speakers for the rest. Will the Dipole and box speakers intergrate well or should I build all box type speakers?
Is the Speakeasy the best for designing box speakers also?
Thanks, Rick- Bottom
There's no such thing as the "best" software. Both SoundEasy and LspCAD will work with DCX files. SE has a better overall measurement features, but is pretty user hostile (plan on buying JohnK's add-on help tutorial). LspCAD is more intuitive but it's measurement features are limited to those in JustMLS program.
Either SE or LspCAD will design a 'box', so will numerous freeware programs. The trick is to correctly design the crossover. All programs require the user to have knowledge about crossover design. Since all the programs are is a software shell running fairly generic equations related to the kind of crossover the user chooses to create. (IOW, if you don't know how to design a crossover don't expect software to do it for you)
There are several freeware dipole modeling programs. 'The Edge' is one a lot of people use.
The choice of dipole or box is up to you.
I don't know very many people running 7 channels of dipoles given how they must be placed in the room
I strongly recommend that you do not attempt to design your speaker system from scratch because there is alot more to it than plugging some figures into a software program, and it spitting out a diagram of what you need. You might want to check out the Mission Accomplished threads... :TMichael
Chesapeake Va.- Bottom
For now I am going to use the DCX2496 (I puchased 4 just in case) on one pair at a time until I gain more understanding on the effects of a crossover system. Also I will just use Open Baffle speakers for the mains only since my room is so small.
Thanks for all your help!!!!!!!!!!
Rick.- Bottom
