Speaker Spikes/ Feet
  • BigguyZ
    • Jan 2009
    • 153
    I don't remember exactly where I saw it, but I recently saw a picture of a DIY speaker that had some really coodl speaker spikes on it. The spikes were on the bottom of a "pod" that jutted out of the side corners, rather than just bein affixed to the bottom. I've seen that style foot/spike on some commercial speakers, but can't find anything on any speaker building websites/stores.
    Anyone familiar with what I'm describing, and can you tell me where I can buy them?
    Thanks!
    Travis
    Those were from PE and they were discontinued long ago..
    • ripcard
      • Sep 2008
      • 40
      Maybe mine?
      Dynamic 2 T Mod
      My CLD Dynamic 2T, 2CC, 1S and RBR builds. My CSS Quartet 15 build.
      • BigguyZ
        • Jan 2009
        • 153
        YES! Those. Are they also discontinued? I really like that look...
        • djn04
          • 49
          These are nice also but not cheap. I bought the spikes only and made my own outriggers from MDF
          • ripcard
            • Sep 2008
            • 40
            Nope, far from it. Check in my build thread for the link or go to the Canuck Audio Mart website and search for "Extender feet". A fellow by the name of Charles Gruss from FCC sells them. They are used by a Canadian high end speaker company around Toronto. They come in a couple of different versions. Not exactly cheap but very nice quality pieces.
              SOLID ALLUMINUM Outrigger Extnder Feet for Most Floor Standing Speakers.Price is ONLY for SET of 8 Outrigger Feet. The Brass Spikes are sold Separately.Gives you better BASS Response and Speaker Stability by extending the 'Footprint' of thespeakers by +- 3".Feet are used with Large Brass spikes for...
              • BigguyZ
                • Jan 2009
                • 153
                Wow, that is expensive, but I think worth it to get that look. Now where do you get those particular brass spikes?
                Edit: Nevermind, I see that he sells those in another add on the same site. Wow, really $$$$.
                Is that in Canadian $, or US$? Eh, I guess I'll find out when I order...
                • ripcard
                  • Sep 2008
                  • 40
                  Canadian Tire money. For you...a 20+% discount. Might be duties bringing them across though.
                    Considering the amount of metal they aren't out of line.
                    It would be a fairly small portion of the build price of a set of Statements, Khans or ZRTs even if the price was US$
