I think I've bottomed the drivers on my NatPs. I'm testing the crossovers, and with a T-amp, there is no problem. The bass is slightly thin, but I attribute that to the T-amp.
However, when I switched to the Onkyo TX-SR505 that I plan to use to power them, several seconds into Bach's Toccata and Fugue in D minor, I heard a thump, the woofers moved a lot, and the music stopped for a moment. This happened at a crossover of 200Hz, so I'm assuming it's a crossover problem, not a full-range problem.
Is that "bottoming the drivers?" If so, I assume it's disastrously bad. What might I have done wrong, and what should I do to fix it?
I'll attempt to post some photo-bucket photos below - I hope this is the correct photo posting etiquette.
Images not available
