The partsexpress BR-1S kit went on sale for $99 and I figured, what the hell, why not. So I ordered them and built them and now I'm thinking, What the hell? I guess they don't sound bad but I expected a box big enough to fit my head in with a 6.5 woofer tuned to the 30hz range would have a bit more bass. Instead they're just sort of uninspiring, kindof bright, or maybe midrangey. I can't tell I've just been letting them run by themselves in my spare room for 2 days hoping the woofer will loosen up and the tweeter will chill out.
If I don't just put them on craigslist they'll probably end up hooked up in the living room where the sonically impaired watch tv and movies.
I didn't really expect the kit to sound all that great, what I figured it might do is boom and bump and generally play that rock music that sounds nasty on the really good speakers in an acceptable way, but so far I'm not feeling it. I was wondering if anyone else has built this kit and tinkered with it or has any sugguestions, like yank the padding out of the box or put a resistor on the tweeter or something. Btw I added dowles to brace the front and back and side to side. If anything I'd think that should have helped the sound of the somewhat flimsy box but if anyone thinks otherwise let me know.
I should measure the port and model the box, maybe if I cut the port a bit shorter and moved the tuning up 10 or so HZ that would reinforce the musical low range of 40-80hz
Well I can boost the low end a bit by raising the port tune from 38 to 43 which according to WinISD raises the response to about 45hz.
