Im getting ready to complete my sonotube. I am trying to figure out how to get the best / straightest cut of the tube. I can cut the 2 internal braces to the correct length and place them inside the tube then install the internal caps. I have about 66" of tube and will be using about 56 inches. So, what is the best way to cut the tube? Jig saw, router (if so how?), other ideas?
I used a circ. saw on my last tube, while it did the job it didnt give me the straightest cut.
Thanks again and again,
Gregg
Gregg
