I'm a new member, and have been reading several threads over the past few weeks trying to get some ideas. I am about to finish a center channel speaker project (ZD3C) which I was doing to refresh my woodworking skills before taking on this sub. I have posted the thread shown below over at the Parts Express Tech Forums and AVSforums, and I thought I would repost here to get some additional responses...
----------REPOST----------
I posted here a few days ago about my center channel project and was impressed with the quick and helpful responses. Unfortunately I had already started construction on my project so I didn't get the full benefit of everyone's advice (although I think I made changes that will drastically improve my finished project).
I thought with my planned subwoofer project I might post BEFORE starting this time.
My room is about ~4,000 cubic feet, but opens up on two sides into probably another 10,000CF of the house. I use my setup for about 95% HT use, and am not a critical music listener. I currently have a Velodyne VRP-1200 that struggles along from it's position in the front right corner of the room. The idea is to use (2) RSS390HO-4 drivers downfiring in a ~7CF vented box, with an ep2500 amp.
I've read in several forums that using a subwoofer enclosure as a coffee table is a bad idea because it doesn't allow for optimal placement, but I think if I want to get a box this big into my room it's the only way. Ignoring the placement problems, please give my drawings a quick look and let me know if I'm on the right track. Most of my dimensions were determined by looking at an existing coffee table and trying to stick with pieces that can be cut out of 24"x48" "handy panels"...
I've neglected bracing in my drawings, but realize it will be important to brace heavily based on the size and weight of my design. I'd plan on using probably 4 window braces across the short axis of the enclosure, and one or two spaning the length of it. If I figure 3/4 of a cubic foot for bracing and driver displacment, and use WinISD beta to model the enclosure with 6.25CF @ 25Hz it looks like (2) 4" ID ports at a 14 inch length should work nicely.
One question I do have, is if the ports' area displaced inside the box (about .32 CF) should be removed from the internal displacement of the enclosure and remodeled in WinISD (which would change each port's length by about inch or so)?
I'm also wondering how much difference it will make if I face the ports towards the couch, or oppositely towards the open end of the room facing the rest of the house...
For anyone who is interested, I plan to use 3/4 inch MDF veneered in red oak to build the subwoofer enclosure, 4" PVC for the ports and legs, and birch plywood for the base plate and the tray on top, which would be filled with 12"x12" granite tiles (much cheaper at $4 per tile than a granite slab). I'd like to keep the top tray unattached to the enclosure (it's weight should be enough to keep it on there straight) so that if I move it can be removed to split the weight up. Also if it ever gets damaged, or doesn't match my interior decoration chioces I don't have to start over from scratch.
Questions, comments, thoughts, links, ideas, rants, etc are all(ways) appreciated.
