New kid needs some advice from the sub gurus.
  • Dean Coop
    • Feb 2001
    What better way to use a first post then to ask a simple beginner question right?
    So here it goes:
    Do I want a ported or sealed sonotube sub?
    Here are the variables that go into the answer:
    ---This sub's main purpose will be for HT.
    ---I like deep clear bass with no distortion, loud is good but reference is too loud for me. So if the sub can reach reference its well within my needs.
    ---Size isn't an issue, I have a corner in my HT that’s just dying to be filled with a big 18"-24" by 6' monster.
    ---The driver I plan on using is the Adire Audio Tempest, which looks like its a little better suited for a sealed cab, but (as others have proven) will definitely hold its own in a vented cab.
    ---My room is 15' long 17' wide, has a large opening in the rear and a vaulted ceiling.
    Right now I’m leaning towards the sealed cab because its simple and for a first attempt at something simple is usually the best way to go IMO. But will I be missing out going with out the extra db at the low end the port would give me? Tell me what you guys think.
    Thanks in advance
    Dean
    • 10931
    Hi welcome to HT-Guide
    If you want the best performance and to decrease the risk factor use one of the designs already proven for a ported Tempest. So checkout these threads then ask any more questions you might have. Sealed subs hold no real advanatage over ported design specially for HT use.
    • Lexman
      • Jun 2000
      • 1777
      Hey Dean, welcome to the Guide. My personal opinion is, that if you are going to go sealed, consider a traditional sealed enclosure. I don't know of many sealed Sonosubs that have been built. I have no empirical data as to why you should. Just call it a gut feeling.
      Thomas, thanks for pointing him to the links.
      Abzin, welcome to the Guide as well Dean! Don't forget to register for the DVDs in DVD Lotto!
      Lex
