question for thomasw (sonosub)
  • chris wood
    • Jan 2001
    i recently looked at joeys website and emailed him about his sonosub that you helped build he emailed me back told me to ask you about the dim. of the sub any help would be great im going to be using the same sub and powering it with a carver tfm 25 which runs 350 mono or 225 steeo each channel
    thanks again
    Welcome to Ht-Guide
    What are the dimensions? To be honest it's been so many projects ago I don't remember all the specifics
    Lets see, he used 24" diameter tube, and we designed a sealed enclosure with a Qtc of 0.5
    If you want to copy his, get Joey to give you the height of the tube excluding the decorative top. Make the end caps the same thickness, 2-3/4" layers of MDF with 1-7/16" layer of OSB.
    The damping material was put in at a rate of roughly 1-1.5 pounds/cubic ft. It was then tuned by ear for the best sound.
    You've got plenty of power, run the amp in stereo, one channel/voice coil.
    • Joey Millison
      • 1022
      Glad to see you joined in Chris I hope you'll be as happy with your sub as I have been with mine, though I'm sure you will be
