Wilson Audio X1-SLAMM "klones"
    How about saving $70,000+? :E
    X1-SLAMM klone project "work-in-progress" pic
    Wilson Audio, X1 GRAND SLAMM site
    • 15290
    Gee, that puppy looks kind of heavy.......
    And a little familiar, too.
    Wonder what kind of subwoofer you should use with something like that?
    -J
    • Lexman
      • Jun 2000
      • 1777
      Outstanding job Thomas and Jon. Perhaps an east tn audition will be in order? lol. I can always hope
      Jon, maybe you can run them full range if you push them?
      Lex
      <A HREF="http://www.catcables.com" <IMG SRC="http://www.htguide.com/lexman/other/sm_logo.gif"
        • 16507
        Nice speaker. whats the advantage of having the bottom midrange speaker in the MTM array pointing upwards, wouldn't this be firing up above the listeners head?
          Andrew
          The top modules function as a "focused array". The angles of the top and bottom 7" are "aimed" and they converge at a fixed distance in front of the speaker. This creates the best "sweet spot" posssible.
          Jon will be glad to go into detail regarding this when he has time.
            • 15290
            Thomas explained it fairly well; this configuration produces a better vertical dispersion in the upper midrange/low treble, improves the correlation between axial response and room power response, and reduces destructive interaction between the drivers in the region above 1.5 kHz. Don't credit me, credit Dave Wilson. I've designed and built conventional D'Apollitos, also, on flat baffles, including one with the same set of drivers and basic crossover; they don't work as well or sound as good.
            • John Holmes
              • 2703
              Thomas, Jon,
              You guys do awesome things when it comes to building. My hat goes off to you! I hope that one day, I will be able to try some of the wonderful plans and ideas that you gentlemen put before us.
                • 15290
                Lex,
                I call these "Maxi-Monitors" - kind of like "mini-monitors", only a little bigger.
                The bass tuning is to optimize output and dynamic range for music, so they aren't designed for high output at 16 Hz, rather, each cabinet can max out at about 118 dB at 1 meter cleanly from about 30 Hz up. This is a function of the cone area, power handling, xmax, and port tuning. Also, this is an overdamped alignment, which requires a simple shelving EQ (adjustable) to tune for flat response in the room they're used in. The custom electronic crossover for these is an intersting piece. It also includes baffle step equalization for the upper module. As efficient as these are (94 dB for the top module, about 98 dB for the bass bin), it doesn't take a whole lot of power to drive these, just something comfortable with variable load impedance, and reasonably low output impedance over the whole audio spectrum. In fact, the last couple of weeks I've been driving them with a "bargain basement" Sony TAN9000ES 5 channel amp (bargain, because it was bought from a Sony Outlet store as B-Stock). Very credible performance, from a nice, compact package (the amp, not the speakers!).
                Used to be 30 Hz was a fairly full range speaker, and they sound fine on music. But, for Home Theater, maybe a little re-inforcement below 35 would be desirable. If I had more room, I think an IB woofer like Tom's maybe with the 15" Adire's, would be great. The problem would be trying to match the output capability.
                  Here are some "spy" photographs of the custom active XO Jon built for the SLAMM klones. As with most spy photos they are a little blurry to obscure the details
                    • 15290
                    These "Spy" photographs were taken by one of Santa's elves that had been drinking too much Egg Nogg with rum, and was using the camera "handheld" instead of setting up the tripod.
                    All those funny transformer looking things near the connector panel are Jensen output transformers (balanced outputs), with -3 dB bandwidth of 0.1 Hz to 15 MHz. (Who says transformer coupling can't be wide band?). Connectors are Neutrick and Cardas.
                    The klugy looking board with all the blue square things (power transformers) and caps and heatsinks is a handbuilt power supply PCB.
                    The two identical PCB's are the crossover/output circuits, designed using Protel 99SE for schematics, simulation, and PCB layout. Bare doubled sided PCB (wtih ground planes) fabrication by Cordova Printed Circuits in Silicon valley (don't do this in your home!)
                    Burr Brown OPA627 DIFET opamps are used with Analog Devices AD815 (dual half amp, 15 MHz video power buffers, yes, they're equipped with heatsinks!) in the primary signal path, and OPA2134 in the LF sections of biquad filter. LF EQ and baffle step EQ is inlcuded in the output buffer stages. 10 turn metal element pots with counting dials are used for precision and low coloration (comparable to Shallco attenuators as pots).
                    Other than that, the spy Elve couldn't remember anything- too much rum in the Egg Nogg.
                    -Jon
