My First DIY Sub finally finished!
  • BIGDAWG56
    • 8
    Did a infinity simple 12 sub its all finished except waiting on my amp. If i decide to build another one their are a few things i would do different just for my benefit (like not rounding over the corners of the cabinets; would make install the black ash vinyl laminate much easier) also not have the depot cut all my wood ended up having to redo alot just because it was very off measurements.
  • vinceb
    • 55
    It looks good, that's a very interesting cabinet interior, the slot port is cool. There's nothing like your first one! So in the first picture is the front of the cabinet down and the port exit pointed down? Just trying to get my bearings on what I'm looking at. What's the cabinet tuning?
    I did the vinyl on my sealed subs and one day I'll peel it off an do them better. It was quick and easy but it has tiny bumps all over from dust on the cabs and wood fibers, not quite as clean as I hoped but OK.
    • BIGDAWG56
      • 8
      no in the first pic the front is to the right, your actually looking at it from thru the right side. its tuned to 19hz. the port exits out of the bottom and it has 8lb of mineral wool directly behind the woofer glued to the large cross-brace
