I was talking with a friend about my speaker building experience and how much I'm loving it. It turns out that he's in the market for home theater speakers. We talked about his desires and limitations. He's thinking about a 6.1 set-up and liked several things about a particular Definitive step-up that was a L/C/R sound bar and 2 satellites with a rear center.
I had some questions for him about the available space for the L/C/R so those questions will come later.
For now, his requirements are for small satellites and rear center. From his descriptions, I think I can squeeze 4L out his limitations if I use 0.5" MDF. After a little time researching, I think I simply need to attain ~80Hz out of the satellites. The RS125-4 hits 81Hz in a sealed enclosure, but all indicators say vented. Do you think this would be a good solution?
There is an interesting alternative, using a single Peerless 5.25" PR. in the same sized cabinet. This nets an F3<70Hz and the PR hits it's xmax above the box Fb resulting in sealed-like cone control below that frequency. What's your feeling towards this enclosure?
FYI: The RS125, 4 and S8, really response well to this PR and I'm considering a dual-PR-per-driver alignment for the L/C/R bar (given sufficient surface mounting area.)
Last question is, can the rear center speaker be a satellite or should it be just like the front center channel speaker?
