Other than some additional work, is there any disadvantage to mounting crossovers for large-ish floorstanding speakers inside their own small wooden box, which can be built onto the rear of the main enclosure? It seems there is frequently inadequate space inside the enclosure to maintain recommended minimum inductor spacing, so a separate enclosure, properly constructed so it would not rattle would solve this problem, and provide ready access for component replacement...
Bruce
Bruce
