Eton Symphony 8
Why does Eton just show from 400Hz?
In a small non-anechoic room, the MLS signal has to be gated to eliminate the reflections from the adjacent surfaces. 300 Hz is about the lower limit of reasonably accurate response in a normal size room. They could show lower, but the curve would be meaningless, as are most MFG's plots that show data below 300 Hz.
Model the drivers response in the box of your choice and splice that response to this one at 300 Hz. Unless you are measuring outside, or in 2pi in a very large room, this is as accurate as it gets.
C- Bottom
