Let me start off by saying Ryan and cjd I am sorry it has taken me so long to get this thread started. Work has been a bit crazy and my phone / camera broke midway through this build, but I have finally gotten them done and have pictures.
With just finishing the addition onto my house it is time to start getting items for the theater together. I decided to start with speakers, and was set on purchasing them but could not find anything that I liked within my budget. So left building them, but I have never built nice looking full range speakers before. I have built a few subwoofer enclosures before but never tried my hand at mains. I guess I jumped in head first, but thanks to K and cjd for there work on the Khanspires.
I actually started with the center channel in this build, though I did not go with a pre-designed unit. I decided to take the same drivers as in the towers and transform them into a center. I used the same internal volumes as the towers have. I changed the layout of the drivers which could cause me to make changes to the crossover a bit. At this time I am using the same crossover as in the towers since I have not had time to take measurements and see if any changes need to be made. It does sound darn good though! I also changed the shape of the enclosure, adding a curved top.
Ok enough talk time for some pictures.
The clamping or strapping of the curved top
After Bondo and sanding
Cherry veneer applied
Finished
After finishing the center I felt pretty good. The curved surface on the top of the center didn’t go to bad so I thought why not curve the sides on the tower speakers. Wow this was a pain in the butt! I spent more time clamping and strapping the sides of the cabinets than I did with the rest of the build parts put together. I do feel that the multiple layers of hard board was the easiest way to go it was still very hard. On the other hand I really liked the way they turned out. This is when my camera broke so I do not have very many pictures of the build.
Again here are the pictures:
Clamping up of the front baffle
The front of one speaker and the side of the other, a bit of a cluttered mess but only picture I had.
Finally finished! I used the same cherry veneer as I did on the center, but painted the back and bottom of these in black paint as you will never see it.
The back of the speaker
Finally I am throwing in a few pictures of the rest of the room as I am slowly working on it. My goals right now are:
1. Doors in the back
2. New Sub, when my Maelstrom arrives (I hope in a week or so)
3. Stand for the center channel
4. Acoustical treatments which will cover the windows over completely.
More to come.
RLH
Finished
More to come.
RLH
