I am at the prototype testing stage of my original design OB mids/tweets section of a projected 3 way system. I would appreciate input from anyone experienced with OB implementation.
Two 4" mids and a Peerless HDS tweeter are mounted MTM. Spacing between drivers is very close, with mids slightly overlapping tweeter flange. Baffle width is 15", with the outer 3" of both side edges curved into a 3" radius (essentially "wings" that curve toward the rear). The drivers are offset from centerline by about 2". Xovers sound reasonable; I have no method of testing actual FR, but a CD with test tones sounds pretty smooth from 400 on up, as designed.
My question is about imaging. Mono recordings stay very well centered and have nice 'depth", but on certain stereo recordings, the image seems to jump from one side to the other, depending on frequency. Is this the "problem" that some builders report with OB designs? Is it due to baffle width, driver orientation, or could it be Xover anomalies or inequalities? I did not carefully match components between channels, as this is only the prototype stage, but all components were within 5% or so of label values.
I really like the tonality, dynamics, and spatial qualities of the OB format, but I could never live with this wandering image. Please help me solve this problem.
Peace
Tom E
Peace
Tom E
