Hello all,
I can finally see the light at the end of the tunnel! Cabinets are almost ready for veneering (all sides except the front baffle.) I'm planning on painting the front baffles to match the black frames on the accuton drivers that I'm using. (I'm guessing the closest finish would be an eggshell finish.) The front baffle is very complex. (see picture) I'm filling cracks/ breaks between pieces, but since it's plywood (and mare than a little complex) it's never going to be perfectly smooth. It's my understanding that you're not supposed to sand primer. I was wondering if there was some kind of hard core (thick) primer that I [i]could[i] apply and then sand until smooth. I was just planning on using black from a spray can for application. (shrug)
Any comments or suggestions greatly appreciated. Thanks!
Hello all,
