For those XO geniuses...
So I've got a 2ohm SVC 12" Sub with these specs:
Qts : .375
Qes : 0.49
Qms : 1.506
Fs : 25 Hz
Re : 1.8
Vas : 157 L
MMS : 90g
BL : 7.2 Tm
SPL : 89.1 dB
SD : 510 M^2
Xmax : 9.1 MM
Since I can't find a cheap (under $120) amplifier that'll handle the 2ohm load, will the resistor in the link below get me to 4ohms or higher load to the amp? It's an Ohmite 2ohm 100W tunnel style power resistor which would essentially create an L-pad to attenuate the sub.
HERE
If not, what load would connecting that resistor in series to the sub give me for loading on the amp? Will I need other components to get me to the 4ohm (min.) loading? Also, will this reduce the output levels (dB) of the sub or the sound quality?
Qts : .375
Qes : 0.49
Qms : 1.506
Fs : 25 Hz
Re : 1.8
Vas : 157 L
MMS : 90g
BL : 7.2 Tm
SPL : 89.1 dB
SD : 510 M^2
Xmax : 9.1 MM
HERE
