The ZDT3.5 taught me a lesson... at first I thought it was aggressive sounding at high levels, since my Neo8 / Neo3 design sounded better at any listening level.
Here's the room they were in.
Not as much a room as a huge, open space with hardwood everywhere.
Then, I decided to move the ZDT to a room with some carpet, lots of furniture, etc. The speakers sounded a lot better.
I took out the Liberty RTA to see I wasn't imagining things. Here's what I found (sadly, I didn't save the screens).
So, I guess the problem in the bigger room is an excess of midrange energy, plus not enough bass reinforcement.
I assume the Neo8 / Neo3 design doesn't have this problem (it measures really well using Liberty) because of their limited vertical dispersion.
There's no way my wife will let me buy a carpet for that place. She loves the floor.
So, what kind of design would you attempt that would minimise floor reflections and the overall contribution of the room to the sound? The Neo8 / Neo3 design did it pretty well - I suppose a combination of big woofers and drivers with limited vertical dispersion would do the trick.
I'm thinking about a design with a pair of woofers (8"), vented, with an MTM array using the TB Titanium. I suppose that would limit vertical dispersion. I don't know whether to go with an open back baffle for the mids, or doing a sealed box. The tweeter would be a Seas 27 TAFN.
Do you think this would help?
- The smaller room had a bigger bass boost
- The smaller room had a nice drop-off starting at 1 KHz
- The bigger room had a nasty peak at 2 ~ 4 KHz.
- The bigger room also had a dip from 250~600 Hz
- When measuring the speaker at 1 meter using Liberty, FR was basically flat.
