I recently came across a barely used EP1500 for $100 so I did what anyone would do and bought it. I would like to use it to power a 12" or 15" sub. This will be for 90% HT and 10% music. Right now I have an HSU STF-2 so I'm looking for something that will outperform that.
I am leaning toward the Tempest-X but am not sure if I want to go ported or sealed. Any recommendations on this? The max size for the enclosure is roughly 18"x18"x36". I can go a little bigger than the 18" but not the 36". The wife has decreed that it must fit behind the couch. 8O
I read through the Tempest application notes and it says that I would need to EQ any sealed sub. I'm not really sure how to go about this. What is a low cost solution for this?
Ported/sealed? EQ/No EQ? Tempest/Something else? I really just need some guidance from you subwoofer gurus!
