Hello Guys....I've got 2 15" Tempest-X 15" drivers and I'm ready to build, but I need some Info. My plan calls for both 15's In the same box, 48"W X 28"H X 20"D,the box will be sealed.The sub will be used In my home theater for movies and music.The drivers will be mounted on each end of the box with a Internal volume of about 14cu/ft, accounting for bracing. My questions are:what effect will the drivers have on each other,being loaded In the same box and will mounting them in a opposed position have a negative effect. The last question is,should I use two independent amplifiers because the Tempest-X drivers have dual 8ohm voice coils and will result In a 2ohm load which my 1000 watt PE plate amp won't handle.....Thanks guys
