Small in the wall rear design??
  • bobhowell
    • Jul 2008
    • 202
    I want to built an in the wall set for my HT.
    I have made 3 ZBM4 and 3 Zaph HVI W5/Vifa D27. I have parts for 4 more ZBM4 for gifts.
    What designs work "in the wall"?
    I have looked at the PE Showcase set this Fall.
    Also curious just how you would adapt a design. What have people done?
    Bob
  • bobhowell
    • Jul 2008
    • 202
    Does anyone do this. I thought I had seen post about this somewhere; Designs that can be adapted.
      • 5204
      You didn't give people much time to respond.
      It is done. CJD just did some big 3-way inwalls for his theater. Probably in the summer, we're going to do some mid-size in-wall 3-ways for my rears. So you're not crazy with the idea.
      There is an in-wall crossover for both the ModulaMT and NatP. Beyond that, there aren't many in-wall designs here or that I know of on the net.
      • HareBrained
        • Jul 2008
        • 230
        Any design can be adapted. Essentially, the effects of the BSC need to be removed.
        I've been able to reverse engineer a couple of Zaph designs to have the model reflect his in-box measurements. If you were to do the same with whatever design you liked, you could then model without the BSC and net an in-wall design with a similar frequency response. There's no reason the ZBM4 couldn't be your starting point.
        You need to state your L/C/R speakers so the people can recommend similar designs that might integrate with your system.
        John
          Modeling backwards to an in-wall concept is as tricky as any minimum phase modeling project - results can vary widely based on how close you get on all the parameters you probably have to guesstimate at (like z-axis offset).
          How big do you want your in-walls to be?
          • bobhowell
            • Jul 2008
            • 202
            I have the Zaph HI-VI 5/Vifa as L/R/C. I was thinking of the ZBM4 as "in the wall", as rear speakers. Zaph has a crossover without BSC I can use.
            Do I need to stay with the baffle dimensions, as it will be close to flush. I know I can make it longer ,..but wider? How to get the volume is the question.
            Just what matters?
            Bob
            • alias2
              • 50
              Bob
              There only seems to be a reduced BSC option ? not one with no BSC at all ?
              The more flush it is the more you can ignore the baffle dimensions. /alias2.
