I feel modal resonances in midrange enclosures are significant enough to warrant thorough examination as to alternatives to a traditional sealed midrange, but am currently not interested in a dipole or cardiod dispersion pattern. For a traditional sealed enclosure, the largest internal dimension would have to be 1.67" to place the first modal resonance one octave past a 2khz crossover point. This is of course highly impractical.
This has got me interested in midrange transmission lines.
As long as the line is stuffed, the resonances along the length of the line should be attenuated significantly due to the high particle velocity at the open end of the tube...but what about the resonances that propagate along the radii?
Is there anyway to deal with the radial resonances other than building appropriately sized diffusors in the interior? Wouldn't the particle velocity be 0 at the walls and the pressure be at maximum, thus negating any absorptive effects of foam for radial modal resonances.
