Aluminum midrange recommendation
  • LING GOWA
    • Dec 2007
    • 165
    I'm trying to find a high quality aluminum 4'' mid for under $100.00 USD.
    About 90 db (1w/1m)
    Flat from 500 Hz to 3500 Hz
    8 ohm
    Website
  • Mazeroth
    • 422
    Have you selected the other drivers to compliment the mid?
    • Jed
      • 3621
      About 90 db (1w/1m)
      8 ohm
      Can it be Ti? TB W4 1337 of course. :B I'm not aware of any aluminum driver that can outperform it as a 4" mid.
      • LING GOWA
        • Dec 2007
        • 165
        2 Seas L18RNXP + LCY130
        Website
          RS52, though 500Hz is the bottom end of what it can do. And it's not 4".
          • Jed
            • 3621
            Forgot the RS125. Very good driver- though I wouldn't take it much higher than 2.5k.
            • HareBrained
              • Jul 2008
              • 230
              Vifa PL11. Not metal but is Twiggy-flat with a high efficiency for your desired range.
              John
              • thadman
                • Jan 2007
                • 248
                you're asking a lot of bandwidth from a rigid cone, what drivers will it be crossing to?
                • cotdt
                  • 393
                  the Jordan JX92 can do it... it has a properly dampened aluminum cone...
                    • 16073
                    So can the W4-1337SA.
                    • thadman
                      • Jan 2007
                      • 248
                      Very nice example, although its very expensive and it doesn't quite have the sensitivity he may be looking for.
                      • cotdt
                        • 393
                        You can get the Jordans for $120 each in the group buy, but good point about the price, I guess it still goes over $100. The LCY's are lower sensitivity than advertised, and the L18 woofers are not that sensitive either (if he's going to maintain his 8ohms) so the sensitivity is OK. If the OP really thinks he's going to get to the 90 dB mark there is either something wrong with his measurements or his crossover plan.
                        One more suggestion: RS52 dome mid.
                        OP: Why not just build Zaph's ZDT3.5? You can adjust the crossover to use the LCY's.
                        • thadman
                          • Jan 2007
                          • 248
                          If he can extend his budget a little bit, the Jordans would also be my recommendation since they don't require a low crossover point. The L18s is more of a midbass than midrange with reference to the Jordan.
                          • Jed
                            • 3621
                            These look interesting- though not 90db.
                            • LING GOWA
                              • Dec 2007
                              • 165
                              http://www.markaudio.com/store/alpair/6/round
                              Yes, Ive thought of the MarkAudio Alpairs but haven't seen anyone use them or seen any independen testing. the only info I can find is what's on their site.
                              Website
                              • LING GOWA
                                • Dec 2007
                                • 165
                                I actually have a pair of the P11MH09-08 which I'll be using in another design.
                                Have you used this mid or know someone who has?
                                Website
                                • HareBrained
                                  • Jul 2008
                                  • 230
                                  I have the PL11WH in my computer speakers with a Vifa D26NC05. I got the PL11 on sale from Madisound for $35/. They're typical Vifa paper. Not quite as "airy" as some metal cones, but very full midrange. They seem to have the speed of a good dome but with much better bottom end. I'm using mine up to 5500Hz without issue (figured for nearfield, the higher xo point would keep things cleaner.)
                                  John
                                  • Finleyville
                                    • 350
                                    Not metal but is Twiggy-flat...
                                    :rofl:
                                    • markaudio
                                      The Alpair Drivers are a new product by Markaudio (us) and we are in the process of getting independent reviews and specifications of our drivers. We do have some dealers now (especially in the USA) and so more independent information should be available soon.
                                      All of the non-formal feedback we have received is that they perform to the specs published on our site.
                                      • minkuni
                                        • 29
                                        Are the mechanical drawings of the Alpair 6 correct? If they are, why the odd placement of the screw holes?
                                        Hail to Slay Radio baby!
                                        • Scooter
                                          • Aug 2007
                                          • 8
                                          My vote would go to the Visaton AL130M. It's 5", but fullfills all other criteria very well. It's close to 80€ at the moment, with the falling € it could get within the budget soon :W
                                          • Undefinition
                                            • 577
                                            C'mon Jed, live on the dangerous side! :B Cross it high! Cross it high!
                                            <about to be kicked off HTGuide for metal-cone blasphemy :twisted:>
                                            • LING GOWA
                                              • Dec 2007
                                              • 165
                                              What about the MarkAudio CHR70?
                                              Website
                                              • NorthernGuy
                                                • Aug 2008
                                                • 5
                                                About 90 db (1w/1m)
                                                8 ohm
                                                I think the Visaton AL130M is a good candidate.
                                                Visaton AL130M
                                                Best Regards
                                                • LING GOWA
                                                  • Dec 2007
                                                  • 165
                                                  Visaton AL130M
                                                  Best Regards
                                                  From the Visation graph, it doesn't look very flat. More of a constant rise. $136.85 EACH CAD + TAX + SHIPPING.
                                                  I have 4 L18's that I would love to put to good use. I built Zaph's 'All Aluminum' and it is very nice at low volume. It seems to me that this driver is better suited for low end duty. However, a while ago I had the pleasure of listening to a design with the L18 & HDS tweeter crossed at 1.7 that sounded sweet and played LOUD. I couldn't squeze any info out of the designer though. Too bad since I have a couple of HDS tweets looking for a home.
                                                  I still like the idea of the L18's in a multi way better.
                                                  Anyway, thoughts and suggestions are surely welcome.
                                                  Website
                                                  • davey_m
                                                    • 37
                                                    It also has the double peak breakup resonance typical of the older generation aluminium cones. Newer designs like Zaph's new driver and the Fountek 5" will give you a wider usable bandwidth. But I would not use either of these beyond 2.5kHz.
                                                    • SpeakerGuy
                                                      • Mar 2010
                                                      • 71
                                                      I wonder why you don't see that driver used more? I wonder if the (non-MTM) Sonus Faber Toy / Toy Tower use a straight up PL11, or some variation. I think the MTM uses a 16 ohm version.
