What the heck is going on with this woofer?
Aurum Cantus AC-200MKII 8"
PE posted these specs:
Specifications: *Power handling: 200 watts RMS/250 watts max *VCdia: 2" *Le: .62 mH *Impedance: 8 ohms *Re: 7.0 ohms *Frequency range: 26-3,500 Hz *Fs: 26 Hz *SPL: 90.0 dB 2.83V/1m *Vas: 2.47 cu. ft. *Qms: 4.41 *Qes: .19 *Qts: .18 *Xmax: 8 mm *Dimensions: A: 8-3/4", B: 7-1/4", C: 3-7/8".
Aurum Cantus gives these specs:
The WT3 gives me the following free air parameters with the driver lightly broke in.
Re = 7.05
Fs = 32.3 Hz
Qts = .4485
Qes = .4764
Qms = 7.667
Le = .8579 mH
Has anyone done proper measurements of this driver? At almost $100.00 a piece, you would think they could do better. Will the real AC-200MKII please come on down!
Re = 7.05
Fs = 32.3 Hz
Qts = .4485
Qes = .4764
Qms = 7.667
Le = .8579 mH
