That I couldn't find the answer for with the search or on joewoodworking...
I am to make a pair of bookshelf speakers and am nearing the veneering portion. I decided to use a vacuum press being I am going to go with highly figured burly maple. The glue is Better Bond brand and the veneer has been flattened.
So my idea is to do one side at a time and put it in the press for 5-6 hours each side. I am using a vacuum pump at work which goes to -15inHG, is that low enough? Also should I have to keep the pump running the entire time? I used a check valve but it still seems to leak over time.
Oh and will applying a finish later soften up the Better Bond and make the veneer bubble?
Thanks in advance!
Thanks in advance!
