This is my first post (so be kind).
I have been looking to build Zaph's SEAS "all metal" system for some time now, I was all set to go till the SEAS importer (I am from Aus BTW) sent me an email saying that they do not have stock of the L18 and they are not going to get anymore in
So I am thinking about somewhat coming up with my own speaker, I have set my mind on using the Peerless HDS 830883 mid/woofer (because Zaph gives it a good rap) and I have been looking around for a tweeter to use but I have come back to the 27TBFCG, it also helps that Zaph tells you what needs to be done to it via the crossover (which makes it a bit like the "all metal").
I am looking at using a notch on the woofer of about -4db from 1500hz to 6000hz to get it level with the rest of the woofers output (before x-over) and a crossover of about 2000hz LR4, would this be ok?
This is my first speaker (that I am building) and I hope I have got the jist of what to do.
BTW: I can not get the SEAS reed cone in Aus so the SR71 is not an option and importing would cost a hell of a lot.
