Quick question on Adire
  • bikedave
    • Aug 2007
    • 69
    Does anyone know if the Mpyre 65M is the same as the Adire Extremis 6.8? I see them floating around every now and then.
    Although they share some similar design features (except the cone) I doubt they can be interchanged in a preexisting design.
    • bikedave
      • Aug 2007
      • 69
      Thanks ThomasW, is it safe to assume they share the same motor and basket?
      • Scott Simonian
        • 216
        I wouldn't say so. Although the Mpyre does use XBL^2 in it's motor, it isn't the same motor with the same specs. The basket is also different.
        IIRC, Creative Sound Solutions has a "drop-in" replacement for the Extremis 6.8.
        My Sound Splinter 18's each in 25cuft boxes w/ EP2500
        • bikedave
          • Aug 2007
          • 69
          Thanks guys, that helps a lot!
