I am building Zaph's Hi Vi/ Vifa 5. No more tweeters available( D27SG-05), but Madisound will sell me a similar model with the same voice coil for 60% of retail. I pull out the voice coil and use it as replacement. The rest of the tweeter is a paper weight. Sounds fair. They stock the voice coil alone but are out now. Same voice coil in a series of tweeters.
This happened on my 8th speaker build. The contact pulled loose as I soldered the connection. Got it too hot. So, what do others use to avoid this? Quick connect clamped on?? I have heard others mentioned this problem so I know it is common.
The wire is the size of a hair strand and Larry at Madisound said I would never resolder it. Too small. I believe him. Cautionary tale for others.
So, do you recommend going to quick connects for tweeter?
Bob
Bob
