I am about to start my first speaker building project and need some help with the cabinent. The plans I am following are on the partsexpress website:
From the website the process to build the cabinets is described as this:
Each speaker enclosure was constructed from the following parts:
(2) Side panels: 11-1/2" x 6" x 3/4"
(1) Top panel: 9" x 6" x 3/4"
(1) Bottom panel: 9" x 6" x 3/4"
(1) Front panel: 11-1/2" x 9" x 3/4"
(1) Back panel: 11-1/2" x 9" x 3/4"
( 8 ) Horizontal internal braces: 6" x 3/4" x 3/4"
(4) Vertical internal braces: 8" x 3/4" x 3/4"
The side panels were mitered to 45 degrees on both 6" sides (maintaining the exterior dimension of 11-1/2"). The top and bottom panels were mitered to 45 degrees on both 6" sides (maintaining the exterior dimension of 9"). This permitted the side panels to meet with the top and bottom panels, making a 90 degree corner. All four edges of the exterior facing sides of the front and back panels were routed with a half-over router bit. All parts were biscuit joined, glued, and screwed together to ensure a solid enclosure. Holes were pre-drilled for all wood screws. All internal seams were filled with clear silicon caulk to keep the box airtight, and the enclosures were lightly filled with Acousta-Stuf.
What I need help with is where would the internal braces go and how would they be oriented. Any thoughts on how to lay them out would be greatly appreciated.
