Khancenter + Dayton RS TMWW
  • lowark
    • Dec 2007
    • 8
    Would these be compatible? I know they run the same tweeter and mid.
    Thanks.
    should be, yes. The biggest thing with the Khancenter is it IS designed to be place either on top of or below a big glass box. It will sound a bit funky otherwise.
    Note, the crossovers available for the TMWW are rather significantly different so the sound may not match as well as it could. Significantly different being a relative term - they'll still voice match rather well (much better than, say, a Bose center with the TMWW's... )
    • lowark
      • Dec 2007
      • 8
      Well it will be sitting on a stand above a thin piece of plastic. Hhhhmmmm.
        It needs to "see" an extended baffle. Does that help?
        I think I have the data (did I post crossover variants already?) for a version that could be used with a front projector or similar as well.
        • lowark
          • Dec 2007
          • 8
          Gotcha. :T
            If this doesn't actually fit your scenario I can see about posting/finishing up the other crossover variant, but I won't be able to get to this till after the 23rd sometime.
            • lowark
              • Dec 2007
              • 8
              Thanks for the offer. I think I have decided to go with the dayton center. I
