Hi all,
Ever since my microphone was calibrated, I'm a happy man. My designs now sound like I thought they should. I also noticed I "learned" to get around my calibration issue by designing at 30° off-axis, which basically made my designs flat on-axis with my calibrated microphone. Heh.
Anyway, I was playing around with the Miniliths:
A design which places the Neo3 on top of a Neo8, with a 7 KHz crossover, designed at 115 cms, 0°, for flat response, taking care of avoiding any flares off axis.
I began noticing the speakers were a bit dull on my listening position. After using SynRTA, I noticed there was a null at the tweeter-mid crossover frequency. I was surprised, and re-measured using JustMLS at 1 meter. The speakers were fine. My listening position is 2.30 meters away.
I inverted the tweeter polarity on both speakers, and re-measured with SynRTA. +-5 dB flat in-room at my listening position. And a null at the crossover frequency at 1 meter using JustMLS.
Am I correct in assuming the vertical distance between tweeter and midrange in my design is the culprit? Will the design have nulls or be flat depending on listening position?
I suppose it could be. The Neo8 is a very tall driver, and crossing over at 7 KHz may not be the best of ideas.
