Hi guys,
I've been thinking quite a lot about the ZD5 and it looks like the time has come. I have a few ideas that I would like to discuss though - I really like the translam approach and will definitely go for that. I am thinking about doing it the opposite way of the Magico mini i.e. cut all the panels the size of the side walls and cut the ones in the middle and stack them one next to the other and not one over the other. I hope that makes sense
So I was thinking about using that to make the front and back walls thicker making sure the Revelator can breathe. But I got further - what if I do not cut the inner part straight but in wave patterns hoping to avoid standing waves? If I do it like sine waves the volume will not change and I can do that for all sides - front-back, up-down, the only problem that I can think of is the way I will have to stick the absorbing material (whispermat, felt or whatever I can find).
I will really appreciate any opinion on that, may be I should try and make a small sketch of it, to make it clearer...
